Gas leak
- 91Bear
Gas leak
Whenever I pull the truck into the garage, it reeks of gasoline. I noticed a small puddle underneath the engine (about 1/4 cup). Any ideas where that is coming from? I don't see any leaks under the hood and it is running fine.
Re: Gas leak
fuel pump or the fuel filter ... maybe even the thumb screw on the bottom of the fuel filter is loose (could be why you wouldnt see it).. try looking directly above the puddle or right after you park it stay with it and try to see where it is dripping from.
might have to feel around a bit to see where it is wet...
'72 F100 302 4sp manual
Re: Gas leak
fuel pump or fuel line. check them all look under the truck straight up from the spot on the floor that it is making the puddle at.
