Or maybe even the Sniper2 or ProFlo 4. Any thoughts on that?
Also thinking of changing the cam and lifters and maybe timing chain while I have the heads off for a valve job and more. Want to keep it pretty stock or maybe a bit more. But I want to keep the non-adjustable rocker arm rail. Not sure what the lift and duration the stock cam is. And will a double roller fit inside the existing cover? And benefit of getting a double roller? Has rusty Hedman semi-long tube headers on now and want to get silver ceramic coated ones. Any advantage to changing to a different maker? Hear good things about Sanderson. Will out power steering on it and hope not to hit the Ford PS gear!
I appreciate any help with recommendations on any of the above parts. Been a while since I worked this deep on a car, but it’s getting fun!
