Thank you
240/300 I6 Acceleration/Transmission Linkage
- JWW
I have a 240 that I'm working to get back together. However, I'm missing parts to get the "kick down" fully connected. Below is a diagram of the accelerator and transmission linkage (courtesy of FORDification). I am missing the parts that I have highlighted. I'm not too concerned with some of the bushings or washers. However, I do need the part numbers 7A394, 380340-S. I'm open to buying the full assembly as well if you don't have individual parts.
Thank you
Thank you
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
2004 F150 Crew Cab
Re: 240/300 I6 Acceleration/Transmission Linkage
i have a complete setup off a 67 in very good shape, but its for a 3 speed manual on column. you may need different parts if you have an automatic.
just a thought.
just a thought.
- JWW
Thanks. Is your setup for sale?67 short box wrote: ↑Sun Sep 10, 2023 9:06 am i have a complete setup off a 67 in very good shape, but its for a 3 speed manual on column. you may need different parts if you have an automatic.
just a thought.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
yes. make offer.
- JWW
Can you post pictures of your set up? I want to be sure I don’t already have the parts. Thanks again.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
after looking at mine, i dont have those parts you have highlighted.
- JWW
Thanks for checking though. I appreciate it.67 short box wrote: ↑Mon Sep 11, 2023 8:04 am after looking at mine, i dont have those parts you have highlighted.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
