I recently had my 390 worked over by a local machine shop. 60 over (was 30 over when I bought it), decked a bit, align honed, crankshaft honed, new pistons, all balanced, bearings, timing set, lifters, and oil pump (purchased through the shop; good parts, not parts store junk). Got a good price on having the heads worked on a bit too, with new valves, springs etc, machining on the bottom and exhaust side, and hardened seats. Less than a grand for the head work, which I figured was pretty good since this is going into an F250 and I don’t plan on moving THAT much air.
But I digress. My troubles began when I got home and realized that the pistons he bought are flat tops with eyebrows. I was expecting dished pistons, since we had agreed that between 9:1 and 9.5:1 was the ideal goal. When I picked everything up, he said he didn’t CC the heads, but figured it would be right around 9.25:1. Cool, that’s exactly what I wanted.
But! The H395P pistons, when sitting about 5 thousandths in the hole (which is about what he said they would be), give over 10:1 CR with 72cc chambers!! That’s way above where I wanted to be. I could run a fairly radical cam to help bleed off some cylinder pressure, but at the same time, this isn’t a Mustang...
I still have to measure exactly how far down the pistons sit, but I haven’t assembled anything yet because I’ve been slowly acquiring analysis paralysis researching the rest of the parts for the build. I’m really kind of miffed that I have a whole balanced rotating assembly now that will likely not work for my application.
Was this my fault for not being extremely specific about the desired CR, and not writing it down for him? I don’t know.
What are my options here? It seems like if I get dished pistons, my quench will suffer terribly and I might run into detonation. But if I stick with my current combo I’ll likely have to find a fairly thick head gasket, which lends itself to the same problem.
How does anyone get a 390 truck motor with a low 9s CR and good quench?? I’m kind of at a loss right now and could really use some help and guidance. I appreciate any assistance you can offer me guys.
