67' 2wd to 4wd update...
- zakt
Have the front now on the 85' and measured so now to move it to the 67'... have a pic on my web page of the front on the 85...
http://www.geocities.com/crewcab1967/
1972 Ford F350 crewcab
- ivansgreat
re: 67' 2wd to 4wd update...
Your truck is really nice.
Makes me wish I had a 4wd crew cab. How much do you think this whole conversion is going to cost you?
- zakt
Current:
reverse shackle kit - $500.00
Front 10" leaf & rear 12" leafs - $1750.00 or so
new 85' hangers - $300.00 or so
nerf bars - $300
roll bar - $1000 or so
99' suburban seats - $1500 or so (maybe use 95' F350s)
From my 95' F350:
EFI 460
E40D transmission possibly (C6 from my 85?)
BW1356 transfer case
power steering
seats?
Later:
front rear D60 from dynatrac - $13000 or so
front shock hoops - $399
tie rod & drag link - ?
fox shocks -8- $2000 or so
new drive shafts front & rear - ?
Weld 20x12 cheyenne wheels - $2300
toyo 40x15.5R20 tires - $2300
helwig custom sway bars - ?
vortec supercharger - $1665
460 mas air conversion kit - $1200
BW1356 clock ring - $275
trac bar - ?
flaming river tilt steering column - ?
flaming river steering shaft - ?
Thats a quick breakdown
nerf bars - $300
From my 95' F350:
EFI 460
power steering
seats?
Later:
trac bar - ?
- 72hiboy4x4
Re: re: 67' 2wd to 4wd update...
zakt wrote:Current:
nerf bars - $300
From my 95' F350:
EFI 460
power steering
seats?
Later:
trac bar - ?
OMG I'm having a heart attack!
Will you adopt me????? :twisted:
that will be a serious ride when you are done!
- zakt
I just need to talk my wife into letting me spend it all
- boots
wow man!!!!
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
That's an extra zero in the price for the Dana 60, right? You meant it'll cost $1300, not $13,000. (At least I HOPE that's what you meant!!)
- boots
I dont know about that Keith, ive seen these custom brand new dana 60's go for that much, and used complete dana 60's go for 1,000FORDification wrote:That's an extra zero in the price for the Dana 60, right? You meant it'll cost $1300, not $13,000. (At least I HOPE that's what you meant!!)
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- 72hiboy4x4
yea I 'bolded' that one. I thing he is getting front and rear axles, but thats $6500 each!!!FORDification wrote:That's an extra zero in the price for the Dana 60, right? You meant it'll cost $1300, not $13,000. (At least I HOPE that's what you meant!!)
I am so jealous right now!
Oops...you're right....didn't read that close enough.
OK, never mind.
- zakt
Yep, 13k for both.. mind you that is with 5:13 gears, ARB airlockers, High pinion front axle for the 12" lift (help with driveline angle) then with disc brakes on the rear
- 72hiboy4x4
- HugYourPlumber
thats gonna be one bad mamma jamma
hoosker do's hoosker dont's with or without the scooter stick
68 f250 240cid
69 f100 360cid
Tim Brackeen
68 f250 240cid
69 f100 360cid
Tim Brackeen
