I decided to check if there was any water in the oil, because it was high and slightly discolored before I changed it. Well I think when you take out almost 3 quarts of water before the oil is noticed training there maybe a big issue.
With a little carb cleaner down the carb and gas to fuel pump from a Jerry can it lit right off and ran SWEET!!!
So in about 3-5 seconds it dumped all the oil out of the engine, first thing that came to mind was the rear main seal blew but that seem off for it to dump the oil that fast??
So then after talking with a buddy he thought maybe the cam plug or threaded oil gallery plug fell out.
So what do I do?
My thinking is to pull the transmission to check if the problem can be fixed without removing the engine...bigger job but still may have to be done.
Any thought of what happened or how to approach my problem???
Are there frost plugs on the back side of these 390 blocks? may explain water into oil as well??
Is the pic correct for the FE 390??
