Rochester Quadrajet P/N: 17056212, original equipment for a 1976 Cheby with auto trans. This carb is missing some of the screws that hold the body together so it would be good for parts, $25
Edelbrock 1406, vacuum secondaries, electric choke, 600 cfm. This carb is also missing screws and possibly other parts, good for a parts carb, $25
Holley 4010, P/N: R84012-1, mechanical secondaries, manual choke, 600 cfm. This carb will likely need a rebuild and some tuning, $100
Holley 4160, P/N: 9776, mechanical secondaries, no choke, 450 cfm. This carb is designed to be used as part of a dual carb arrangement, not to be run on it's own, $100
