Any body got a serious interest in buying a Running 428 and a big IN big OUT Toploader 4 speed....The Thunderbolt Tribute car that this is sitting in is a running driving car..... The engine and trans will be pulled out as soon as it is paid for......The seller is pulling the engine and installing his All Aluminum 511 Fe engine and C6 trans...The engine is located 15 minutes from gateway raceway in madison Il ....Engine trans ,shifter,scattershield,clutch Everything from the water pump to the tailshaft is included...This is for a buddy of mine PM your number and I will forward them in the order that I get them ....6500 dollars Try and beat that price any where on the net
Located just minutes from St Louis Mo
I know it is a pretty generic add but some of the numbers I have are
65 date coded C6ME A scratch block
1U crank
C6AE-C rods
New pertronics
The heads are plain jane FE heads
Hydraulic cam
cast iron intake
Lakewood scatter shield
SFI flywheel
Centerforce clutch
Big IN Big Out RUG-AJ toploader
You can go for a ride in the car and see how it runs and shifts
The engine is due to be pulled out in the next couple of weeks or sooner if he has a cash buyer
