Spot weld bit extension
- 67nukeford
As some of you know, spot weld bits are a handy tool, but since most of them are only a couple of inches long, they can be tough to use in tight spaces. I bought the spot weld bit set from Eastwood. Bit works great, but I can't reach into tight corners with it, because of the drill. So, I had the machinists mill it down to exactly 1/4 inch, and bought one of these drill bit extensions from Lowes. It holds the bit snug, no wobble at all, and it works like a charm!
- mybros71
Re: Spot weld bit extension
That's pretty cool. I've never used an extension because of the wobble. What did it cost if you don't mind me asking?
Tony
Tony
2006 Mustang GT (Wife's)
1962 Comet Custom (Wife's)
1971 F100 2wd Prerunner Project (Daughter's)
1971 F250 4wd "The Beast" (Son's)
2007 Toyota Tundra 4wd. (Credit Union's)
Seriously, the best truck I've ever owned, without exception.
- 67nukeford
It's only like 15 bucks or so at Lowes. No wobble at all !
- mybros71
Sorry. I misread your post. I have a Blair bit which is already 1/4" shank. I just need the extension. Now if we could only figure out a way to shorten the drill a.d but to 2 inches.
