I have a 1969 F-250 Camper Special that I recently had some brake and signal problems (see other topic, "Brake and Signal Lights problem"). I corrected the light problem and all is good for now. My truck had the bed removed by previous owner and a stakebed is now there. There is also a towing setup on the truck.
Anyway, during troubleshooting, I disconnected all of the trailer connector wiring. During my troubleshooting, I found another harness that appears to be for trailer lighting/power. There are six wires in this harness and, at least on my truck, there is a connector right about in the area of the secondary fuel tank (on the frame, not in the cab). The connector is flat where all six pins are in a row. Some of the wire colors appear to match those for the brake, tail, signal, backup, and lights. It appears to be an OEM setup.
I ask because if this is original, and is for a trailer setup, I would like to use it to reconnect my trailer lighting hookup instead of splicing into the tail lights again as the previous owner did.
Thanks in advance for your thoughts/experience concerning a harness on your truck(s) similar to what I describe.
Jim
