Will a 69 power brake booster fit a 66
I just bought a 66 F250 off of ebay that does not have power brakes,I have a booster from a 69 that I parted and I need to know if it will bolt on. I have not picked the truck up yet so I cant just check it but would like to know if it will fit or do I have to find one from a 66. Jeff
- 68F250
re: Will a 69 power brake booster fit a 66
Well, I know the '68 and up boosters won't work on the '67 because the brake pedal and setup are different. To put one in you have to also use the '68 and up pedal and convert the stoplight switch. The '67's pedal is like the '66 and earlier. Another thing that may be the deal breaker is your single piston master cylinder. Will it bolt to the booster? Sorry I'm not much help.
Yeah 66's had the single master cylinder resivour (sp?) and I belive the boosters would be different...
- flyboy2610
Re: re: Will a 69 power brake booster fit a 66
Reservoir.oldschoolrods wrote:Yeah 66's had the single master cylinder resivour (sp?) and I belive the boosters would be different...
