Just noticed the other day and have been hesitant to drive it since I noticed.
I have a recently aquired 71 F100 with a 302. Which is quite tired by the way.
So any way I noticed coolant pooling behing the water pump in a lttle valey area near the distributor. Where is this coming from.
Is it just a bad water pump gaket? Or something far worse?
Coolant in an odd place
Russ Stanley
68 F250 ( ol' Grand Dad)
71 F100.( Old Blue)
65 Valiant Wagon (Gone but not forgotten)
2007 PowerStroke(The Golden Goose)
71 F100.( Old Blue)
Re: Coolant in an odd place
It's been my experience when you get coolant there there is a leaky hose going to the inlet. That's the first thin I would check. Make sure the hoses aren't cracked/frayed at the ends, and tighten the clamps. Use a shop vac to vacuum out the coolant so you can see if it still leaks, and at what rate the leak is.
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
if on passenger side i would say a hose if on dist side i would almost guess a leaky intake
'72 F100 302 4sp manual
recently for me i had the little hose's on top on the passenger side come loose and leak it did also get into the valley on the dist side too though so check those three hose connections first. if it is wet under the distributor i would say the intake manifold since there is a water passage right near there (if it turned out to not be those hoses).. but i agree to verify via shop vac and carefull inspection before going to all the trouble to swap water pump gasket or intake manifold gasket
