What is this?
68FORDJBM
What is this?
Post by 68FORDJBM »
What the heck is this and do I need it? It looks like a switch and it's located just above the cold idle adjust next to the throttle linkage. The truck seems to run okay w/o it. I just installed a rebuilt carb which did not include a replacement for this even though it is mounted to the carb. I thought I'd ask about this before I write it off as unimportant.
hazelnut
Re: What is this?
Post by hazelnut »
It looks like a fast idle solinod,lots of older cars had them for fast idle when the engine is cold i belive.but ive never seen one in working condition
Re: What is this?
thats the name of it. i couldnt think of its name.
craftsman
Re: What is this?
Post by craftsman »
They where also used for when you turn on the a/c it would idle the engine up.
68FORDJBM
Re: What is this?
Post by 68FORDJBM »
So, it's safe to say that I don't need it. It's definetly not in working condition and I don't have AC.
cdeal28078
Re: What is this?
Post by cdeal28078 »
I always thought it was used to catch the throttle linkage at the last bit of travel and slow it down so it wouldn't slam shut. I think it was called a Dash-pot or something like that.
71 F100 SportCustom
1986 Bronco 5.0 AOD
Re: What is this?
i would nt trash it just yet. some day you may want it. throw it behind the seat. it will keep there for years insdie of the back seat springs.
george worley
Re: What is this?
Post by george worley »
Its a idle solenoid it is connected to the ignition so it is energized when the engine is running and allows you to have a faster idle RPM with out it running on when you shut the engine off. If you engine shuts off alright then you don't need it.
m-mman
Re: What is this?
Post by m-mman »
The factory tuning of engines in the late 60s and early 70s meant that they tended to frequently 'diesel' when the key was turned off.
Solenoids were used to set the actual idle speed and then when the key was shut off the throttle plates were allowed to shut completely so that the engine would stop instantly.
1969 F-100 Custom Cab 302 T-85 Overdrive, 3.70 equalock & factory 16" wheels
fastEdsel
Re: What is this?
Post by fastEdsel »
:yt: That is definately an "anti dieseling solenoid."
