vibration dampner bolt
lefty loosey, correct? i have put a peice of would and jammed the crank from turning and i can not get this bolt to budge. what gives?
Re: vibration dampner bolt
What gives? Well, obviously not the bolt!
Yep, turn it counter-clockwise at you're looking at the head of the bolt. These are always a PIA to remove, since they're put on with a lotta torque. All I can suggest is giving the head of the bolt a good rap or two with a ball-peen and then find a longer cheater bar. It'll come out.
- TNIceWolf
Or combine the two and smack the crap out of the cheater bar.
Presently in the stable
1969 Ford F-350 DRW
1969 Ford F-350 DRW
- 70_F100
It should only be torqued to about 65 ft-lbs.
If you've got an impact wrench, it should be really easy.
Without an impact, use a longer breaker bar...
That's not an oil leak
- ximy
Did you get the bolt out.. its all about good tools and technique...
1967 f250 428
the longer the lever the easy the pull. sort of like that one saying. the one the girls always joke abotu. the longer the because it isnt the motion of the ocean. becuase they get sea sick easily.
