This is probably a dumb question - but here goes.
If my 352 has 140 Psi in 7 cylinders and 90 in the last that goes up to 137 with oil. what will that do to everyday running ?
what will i see or feel ?
- Stephen
compression test with oil
- stephen44
thanks
Stephen
(1967 F100, FE352, 2wd, 3 on the tree, flareside)
Stephen
- 70_F100
Re: compression test with oil
You will most likely notice a skip on that one cylinder.
It's got to do with the rings.
If you've got a broken ring, and continue to drive it, the ring could cause significant damage to the cylinder wall.
That's not an oil leak
- stephen44
k - thanks
thanks
Stephen
Stephen
