Oil Pump Pressure??
Oil Pump Pressure??
I'm getting ready to pull my 302 in the 70 and put an NP435 on the back and while I had it out I was toying with the idea of upgrading the oil pump.The olny things I'm wondering about is the motor needs valve seals becasue it blows some white smoke and has a little blow by also. Will upgrading the oil pump make that worse until I get around to changing the seals? Also my dad said a hi-po one might cause oil to leak around the rings. The olny reason I'm wanting a hi-po over stock is becasue someday I plan to upgrade the valve train and do a 4bbl and cam swap on it.
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- craftsman
Re: Oil Pump Pressure??
You really don't need anything more than a stock oil pump. The blow by is due to bad rings, the smoke when you start it is from valve seals, I wouldn't put a high volumn pump in it. It want really help with oil pressure because bearing clearence is where you get your oil pressure from.
For now I would replace the valve seals, oil pump,(stock) and timing chain and you should be good for a long while. Even with the upgrades you plan to do doesn't require nothing more than a stock oilpump.
- papabug71
I agree, At this point all I would do is throw on a new OEM pump. I think you will be fine with the stock pump even with the upgrades you mentioned.
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
hi vol oil pumps will pump to much oil. and it will all go to the top end. that is why you must use a holley jet in the rocker shafte to keep all of the oil from going to the top end when a large vol pump is installed. it sounds like it would hurt you more than it would help you.
- 70_F100
Fordman, you're not paying attention tonite.
He said he has a 302...
That's not an oil leak
