dipstick info
dipstick info
I need some help. I cant locate a dipstick and tube for a rear sump oilpan for a390 F E .No-one has been able to locate one.The stock goes into the block.I need the one that goes into the oilpan its-self.Please help
- kaptnkaos
Re: dipstick info
I believe that style was used in FE powered cars with a rear sump oil pan.
I'd hit the wrecking yards and look at full sized cars like Galaxies and even possibly Mercs that were FE equipped.
Good luck...
KaptnKA
S
Good luck...
KaptnKA
Re: dipstick info
i heard someone say the F600 dip sticks may work as well as vans. but i dotn know abotu vans. i think it was just the vans had the rear sump pan is all.
- SteveC
Re: dipstick info
would the dip stick from at 360 4x4 fe truck work? they were rear sumps. The one on my 74 4x4 goes right into the side of the pan.
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
Re: dipstick info
Hello Haayjay,
Milodon makes a rear-sump pan with a dipstick hole in the side, just like you're describing. They also make a dipstick (part number 22034), but I'm not sure whether the dipstick they make is designed to accommodate their front sump pan or the rear sump pan. If you're curious about this you could call and ask, although the price on part 22034 is about $56.
They also make a universal 17" dipstick. This is probably not what you want, but it's possible that they recommend folks use this on the rear-sump FE pans.
I'm using a Lokar ED-5012 on my front-sump FE. Maybe Lokar makes a dipstick for the rear-sump too; you could give them a call if you're interested.
In case you're curious to see the ED-5012, here's my thread about it:
http://www.fordification.com/forum/view ... =3&t=42125
