where does this go?
where does this go?
is this the bolt that goes in the passenger exhaust for the tin heat shield or is this a power steering bracket to water pump stud?
70_F100
Re: where does this go?
Post by 70_F100 »
Really doesn't look long enough for either one.
i think your right. i wasnt sure about the exhaust sutd though. does anyone know what it is suppose to go to?
towtruckerfour
Post by towtruckerfour »
I have a couple like that on my 302 on the passenger side for the heatshield when I had it on.
Troy
Why is it that the trucks are always the best running vehicles in the family?
Ford means "found on road daily"
70 F100 Custom-352 w/68 Highboy 4x4 frame. My play/project truck
70 F250 Explorer-390/C6 auto. My work truck
04 Mitsubishi montero-family car
ToughOldFord
Post by ToughOldFord »
The condition makes it appear to be exhaust, but yeah, it does look kind of short.
Fordman, you need a black keyboard like I have, doesn't show the grease from our parts and fingers so badly. :lol:
BobbyFord
Post by BobbyFord »
Could be to hold the dipstick tube
yuk that does look nasty in that picture. i dont see those hairs onthe kyboard now. i think some of that is cigarette smoke and dust.
bjde0b
Post by bjde0b »
It goes on the 302 stock manifold for a heat sheild. The manifold needs both short and long studs. If you don't have a heat shield then you can put it anywhere, but I replaced mine with grade 8's.
well i found it in the crossover toolbox that i took of fo the capmer special i parted out. i was puttting odd botls and other larger parts in that tool box. i thought maybe i had put the a/c pulley and botls for the power steerign in that tool box. but i guess i didnt. becuase i cant find jack for those botls or the other pulley i had. and i am sure that pulley is different than the one i have here.
anyway that truck had a 360 in it. but i cant be sure where that botl came from. maybe it was already in that tool box.
