Dual Exhaust with Aux. Fuel Tank
SixManCab
Post by SixManCab »
Does anyone sell an “off the shelf” dual exhaust system for those of us with factory frame mounted auxiliary fuel tanks?
Greg Van Sickle
1969 Ford F-250 Crew Cab
2WD 360 2V C6 PS, PB, Onan Generator
Re: Dual Exhaust with Aux. Fuel Tank
i don't think so. they are probably all y pipes and single exhaust.
scott123
Post by scott123 »
I had a set of duals made at the muffler shop for my truck. Bent the pipe from straight stock. 2" duals and mufflers $178
1972 Camper Special
5.0 EFI TFV-IV Ignition Auto O/D
sideoilerfe
Post by sideoilerfe »
you can run dual 2.5" down one side. It fits with no problem. You can even have one tail pipe cross over after the differential and go to the other side if you wish.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
Hooker does, as long as the tank is on the driverside.
You'll have to modify it for anything except thir headers and mufflers.
sideoilerfe
DuckRyder wrote:Hooker does, as long as the tank is on the driverside.
Here's the link I found but there is no photo or explanation on whether it crosses over to the passenger side to clear the aux tank. It's probably for headers only so if you need something for manifolds you might be outta luck.
http://www.holley.com/types/Competition ... ystems.asp
Fordnatic
Post by Fordnatic »
With glasspacks, headers and an RV cam they sound terrific (really unique) if you run duals and tailpipes out the same side with the outlets right next to each other. Different than any other kind of dual exhaust I've heard. I've had 2 78's with 400's set up that way.
70F100: 410 Merc with tri-power, close ratio toploader, 4.56 detroit locker 9"
68F100 4x4: 390, 4 spd/NP 205, Rancho 4" urethane susp, 35x12.50 All Terrain T/A's
55F100
01F150 Daily Driver: TP tunes, AF1 intake, elec fans, Magnaflow exh, underdrive pulleys, Centerlines
sideoilerfe wrote: ...but there is no photo or explanation on whether it crosses over to the passenger side to clear the aux tank. It's probably for headers only so if you need something for manifolds you might be outta luck.
It does crossover, I've posted pictures of mine in the past. They used to list one for manifolds too but havenot for a long time. You could probably have an exhaust shop adapt it to manifolds, but then you might as wll just have them do the whole thing.
SixManCab
Post by SixManCab »
Hey guys,
Thanks for the help. I think I'll run a stock (single) system for now and have a muffler shop weld a dual setup later.
Greg Van Sickle
sideoilerfe
SixManCab wrote:Hey guys,
That also works. Try a bigger pipe like a 3 inch. 2.5 into a 3 works well.
Happy_Camper
Post by Happy_Camper »
For those who have done dual exhaust down one side, did you run a balance pipe? If so, how did you figure out where to run it?
In the past, I've waited to find the "blue spot" on each pipe, and "connected the dots" so to speak. I haven't tried this on a vehicle where both pipes run down one side, and the exhaust pipe on the drivers side is so much longer.
Might be a funky looking "H" pipe ;)
Scott
1972 F250 Explorer C/S, 390-2V, Dual exhaust, C6, Goose neck ball in bed
New and improved with Tilt Wheel, Intermittent Wipers, 2005 Bench seat and 5th wheel camper!...
Life is *very* good!
sideoilerfe
I wouldn't worry about that. Just put one in to balance it out. It's a truck and you won't notice the difference if it isn't exact anyway. That's why I suggested run a single 3 inch pipe.
rjewkes
Post by rjewkes »
Another option would be to have a shop or if you caan weld exhuast yourself, curl the pipe out to run under or outside of the frame missing anything burnable meltable until you clear the obstacle. or roll/bend/angle it out the same way and dump it out the sides before the aux tank.
fuelly.com
