390 oil leak
390 oil leak
I just replaced the rear main, oil pan gasket, valvecover gaskets and still have a leak. The leak on the front appears to be coming from the intake mainfold by the distributor and the leak on the rear is unknown. It seems to be by the rear of the intake manifold. dont know. Hopefully didnt damage the rear main during installation. any ideas?
Re: 390 oil leak
I'd be willing to bet that the leaking is from your intake manifold's end gaskets. These are notorious for leaks. Is this a newly-rebuilt engine? If so, did you use the intake manifold rail gaskets or RTV?
Re: 390 oil leak
well since all of the other gaskets have been replaced. more than likely the leaks are the intake manifold.
Re: 390 oil leak
I suspect the engine is the original 390 (although the sticker on the L/S valve cover identifies a 1970 428, posibly out of a interceptor?) Anyhow, I know its a FE engine and I'm going to reseal the original ford intake man. or posibly install a edelbrock intake. What is your suggestion for gasket sealer for the mating to block and heads and any install tips? what brand of gaskets should I use?FORDification wrote:I'd be willing to bet that the leaking is from your intake manifold's end gaskets. These are notorious for leaks. Is this a newly-rebuilt engine? If so, did you use the intake manifold rail gaskets or RTV?
thanks
justin
