72 f100: need help choosing a carburetor
- madbiker4
Hi, I just bought a 72 f100 ranger xlt and need some help on buying a carburetor. The truck has a 300 cid inline 6 with a Crane cams high lift/high duration cam, Clifford 6=8 4bbl single plane intake manifold , Heddman dual outlet headers and dual flowmaster mufflers. The guy I bought it from sold the holly he had on it, so I have no carb. What I need to know is what size CFM carb should I be looking for to work with this engine setup. I have a motorcraft carb from a ford 490, but fear it will be a little overkill. what dou you guys think? I am willing to buy a new carb ( I'm 19, so I have a budget) but don't realy know what to get. I was looking at an edelbrock 600 cfm 4 barrel from Summit for $250, would this carb work well on this engine, if so is that a reasonable price? I don't have much experiance with truck carbs, though I have been working motorcycle engines and carbs since I was 5. I just wanted some knowledgeable advice before I start working on it. oh, and any advice on where to get the best deal on parts (body, steering, seals, interior, etc..) would be greatly appreciated. thanks in advance.
1972 f100 ranger xlt, 300 cid I6, Clifford performance 6=8 intake manifold, Holley 600 cfm 4bbl carb, Heddman dual exhaust headers, dual flowmaster mufflers, duraspark II, power disk brakes.
- Joshpow
Re: 72 f100: need help choosing a carburetor
I would use a Holley. My experience with the Edelbrocks suck. But, carb choices are just a personal issue I believe. Some people like the pros of one carb and some like others.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
put a hopped up 2 bbl motercraft with an adapter plate that should be plenty i think
if its fixed break it again red white and ford blue the only up hill thats good is the one you are going down
- madbiker4
Thanks for the advice, however I don't have a 2 barrel , so it seem sort of pointless to me to buy one when I could get a 4 barrel for a few more bucks. Realy all I need to know is what size/model/brand 4 barrel should I be looking at? Like I said earlier, I don't know much about truck carburetors. I would prefer to have a 4 barrel , just because it's allready set-up for one. once again, thanks for the help.
- madbiker4
I have been looking at holly carbs and came across their #8007 carb, which is a 4 bbl 390 cfm . http://www.holley.com/0-8007.asp
What do you guys think? would this be a good choice for my 6 cylinder?
Thanks.
Thanks.
- willowbilly3
That's what I plan to run. It is a very popular carb for this engine combination. also 450-500 carbs seem to work well too. I think the 600 would be a little too much.
