Pertronix and coil question
- wickedinhere
I am installing a pertronix points eliminator in my dissy and i know that it is wired to the coil on the positive and negative side.
The power from the truck harness goes to the positive on the coil my question is do i need to ground the negative side of the coil?
The wire from the dissy use to connect to the negative side of the coil i was just wondering.
You can pay more but you cant buy better.
- robwymer
Re: Pertronix and coil question
Wicked,
Before I installed my Duralast dizzy and Mallory ignition, I too looked at the Pertronix, and downloaded an instructional page from the website below:
http://www.pertronix.com/support/manual ... 12vneg.pdf
As far as I can tell, the only wire connected to the negative terminal on your coil should be the black wire from the ignitor.
Good luck!
Rob
Good luck!
Rob
67 F-100 Flareside, 300, Offenhauser 360, Holley 390, Duraspark and MSD ignition, NP-435 4-speed, 3.55 Dana 60, and it will absolutely roast 30" rear tires taking off in 2nd (the one time I tried scared the Bejeezus out of me)
Next engine mod: RV cam (252*)
"They just don't make 'em like they used to."
- 390F100
Red is positive and black is negative. hook both wires from the distributor to the coil, I would recommend getting the flame thrower coil from pertonix as well just to add to it alittle. it is supposed to help quite a bit. but ya both wires from the dizzy to the coil.
390
390
1968 Ford F-100 2wd 390FE
1993 Toyota P/U 22RE
2001 Toyota Camry 2.2
2004 Toyota Solara 2.4
2007 Yamaha Vstar 650 Custom
2007 Suzuki S40 650
2007 Suzuki S40 650
- wickedinhere
Thanks guys i didnt think i needed to ground the coil i just wanted to make sure. I did get the flame thrower coil also with the points eliminator.
Did the same on mine, The points eliminator and the Flame Thrower Coil. Installed over five years ago and have not had any problem at all. I also opened the spark plugs to .045.
Fred
Fred
- Joshpow
Love mine. Well worth the money. Mine is hooked red to positive on coil and black to negative. It is great, and the flamethrower is a must so you can gap the plugs wider.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- wickedinhere
So i should gap the plugs at .045 thats a big difference over the normal gap. Thanks for the info guys.
- 390F100
Whats the deal with setting the gap to .045
2007 Suzuki S40 650
2007 Suzuki S40 650
- 69timemachine
Running a performance coil and the Pertronix should allow for a better spark, and therefore you can get away with a wider plug gap.
I had the Pertronix and an MSD Blaster coil on my Torino I used to have. It ran great!
Crane Cams now makes something similar that I plan on trying out when I put the 351C in my bump. Only their version includes a rev limiter that's adjustable from 4,000 to 8,000 RPM.
http://store.summitracing.com/partdetai ... 00&FROM=MG
Jason
"Where there's a wheel, there's a way!"
'69 F100 SWB in Lunar Green with built 351C & TKO-600 5-speed, 4.56 gears, and Eaton TrueTrac Posi.
Future plans: Maybe one day, fresh paint, though I've been told by some, "Don't touch it! It's done!"
'06 Mustang GT 5-speed
Sold: '77 F100, '72 Gran Torino, '76 El Camino with 454 & TH400
- michael69
When going to the pertronix don't you also need to remove the resister wire just like when using a dura spark.
Just what I was thinking let me know if I'm wrong.
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
Yes, I used a male bullet connector into the female connector right close to the ignition switch out to the coil to bypass the resistive wire.
Fred
Fred
- Joshpow
Yeah, that resistor wire helps a bunch when you replace it with a non resistance one. You get the full capability of the system.
Josh
71 F-100 Custom SWB
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
