oil change
- westernkansas
oil change
I rember my dad use to run deisel thru the engine when he changed the oil in the 1970's vehicles, he would drain the oil dump a few gallons of deisel in where the oil should go start up the car and let it run for a few minutes and then drain it out replace the oil filter then fill it up with oil......says it cleans out all the gunk......there was never a ruined engine either, all the cars he did this too ran strong. would anyone suggest do this to our trucks, I personally have a 390. have 14 days off from work so i plan to do some of the stuff i have not had the time to do like brakes and coolant and headlight alignment.
- averagef250
Re: oil change
An engine that's full of crud will run best if the crud stays where it is. Loosen up the crud and it will float around blocking things up.
Change oil more often and use good oil if you want to keep an engine clean. Modern oil is full of detergents.
Re: oil change
I put ATF 1qt in and that cleans them up. If I worry about crud coming off I get them flushed.
- FORD428CJ
Re: oil change
ATF or Diesel fuel is what I use. Just 1qrt is all you need. JMHO
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
64 Falcon X-Ram 428
67 Stang 351 C/J
Re: oil change
at first that sounds like a good idea. but what about the trapped fuel in the oil pump now. after the flush? maybe it all drains out i dont know. i wouldn't want to thin out my oil. i also wouldn't want it to get sludged up. like was already posted modern oils o have detergents in them to help keep the motor clean.
- FORD428CJ
Re: oil change
If you keep good maintance on your rig......You dont really have any problems!!! Havoline has a lot of detergents in it.
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
64 Falcon X-Ram 428
67 Stang 351 C/J
- FORD428CJ
Re: oil change
Also Sea Foam works awesome!!! I did forget that.....My bad!
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
64 Falcon X-Ram 428
67 Stang 351 C/J
Re: oil change
if you have a lot of funk in the motor, stay away from "cleaning the motor" oll that crap has to go somewhere...Also stay away from any "Engine Flush". Real caustic, and provides NO lubrication to any of the bearings in the motor. As stated, ATF works wonders. I add about a quart 100 mi or so before an oil change. Keeps 'em nice & clean
- westernkansas
Re: oil change
ok ya'll made up my mind no deisel, may try havoline but I always tend to be a trop artic type of guy but it is hard to find around here anymore.
