Electric Choke hot wire???
Where power source do you guys use to run to the positive side of an electric choke on a Holley (I know brand won't matter). Just wondering where you run your hot line from? Thanks
Re: Electric Choke hot wire???
to the stator wire of the alternator. that way it comes on when its suppose to and does run all the time with direct power to it.
forgive my ignorance, but which wire is that?
ithink it is the open one with no wire on it. it should say "s" below the stud.
- rubiranch
And it's usually has a black insulator around it.fordman wrote:ithink it is the open one with no wire on it. it should say "s" below the stud.
- SteveC
mine had a special looking black insulater that made it impossible to wire backwards
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
I wired mine to the fuse block. just make sure its on the correct side so the fuse will blow if there is a shortin the future.
Put it on something like wipers.
I wired mine to the back of the ignition switch on position. Not accessory.
