Here's my plans and I would like some suggestions on witch parts should be used to achieve them.
My truck will be helping me move from the left coast to the right coast. With some fleshing up I don't doubt that it will make the run with little to no problems. I would like to get as much power as I can get for towing and hauling. This will definitely not be a race truck. It is a 1968 F100 LWB W/side tool box 360FE W/3 speed manual moved to the floor LSD rear (I think Dana 30) I would have to double check). At one point the 2bbl carb pissed me off once last time and I converted it to the Holey 2D 2bbl TBI and haven't looked back. Picked up a small amount of power and increased mileage and cold early morning driving. Even though the TBI is a 2bbl unit the kit is designed for use on a 4bbl intake so I had to use an extra adapter and a little custom fab work. I also ditched the engine fan in favor of a high power 16" electric fan. This increased mileage a bit and quitted the engine down a lot. The previous owner ran the original fan direct with no fan clutch. Bellow is a list of what I would like to replace or do. witch parts would be best with my maine goal of towing and hauling power in mind. Converting to a 390FE is out of the question, no money or time for a full rebuild.
1.) Heads need to be rebuilt. Should I use stock heads or are there better heads that would be around the same price range?
2.) 4bbl intake manifold. Should I just save a few bucks and grab the S code intake from the bone yard.
3.) Timing chain needs to be replaced. Are there any manufactures I should stay a way from?
4.) Since the heads are coming off I was thinking of upgrading the cam and lifters. I know didly squat about cam grinds. Should I stick with stock or is there a better choice for me?
5.) Previous owner rigged the exhaust himself and did a crappy job. It is currently a true dual setup with no H or X pipe, and every connection is welded but only about 3/4 of the way around. So there are plenty of exhaust leaks. Should I put on headers, and what size pipes should I use. I would like them to dump ware they are at now, just behind the rear tires. I would like to keep the same type of muffler. Not sure of the manufacture, but instead of being a big oval shaped muff. it is round and not much wider then the pipes. I don't care if it is loud, I kind of like loud. I run a Flowmaster 80 series on my '92 Camaro and love the sound.
Thanks for reading this far!
Will
