offenhauser/headers
- danno
offenhauser/headers
Does anyone have directions on how to install a offenhauser intake with holley 390cfm carb and hedman header. throttle linkage and vacuum hose routeing on a 300 six in a 69 F-100. Any help would be a great help
65 f-100 4wd short bed 360engine c-6 tranny
Re: offenhauser/headers
I put a Offy dual port manifold on my Dad's 240 F100 and a Hooker header later it went on with no hassle. No mods to the linkage or anything. You lose manifold heat when you ad the header and on a winter day in Colorado it was real tough to get started in the morning.
- willowbilly3
This might be a good time to switch to a cable throttle if you haven't already. I know many of the dentsides have them. Last spring I pulled that whole setup from a junker but I can;t remember the linkage. The DP had part of the heat area where the original manifold would attach, hacked away to clear the headers but not all headers will require that.
I strongly recommend anyone messing with a six go browse the Fordsix forum.
- MadMaxetc
I have a 500cfm Edelbrock on mine with a Lokar cable.
check out my website for pictures...as well as photobucket.
http://s63.photobucket.com/albums/h142/ ... 300engine/
Dan
FORD Girl
Photobucket Pictures
FORD Girl
- j41385
What hasn't been asked, unless I missed it, is this... Is it an offy c or dp?
If its a dp the front of the carb faced the passenger front tire. If its a C it faces the way you drive.
1968 F100 Took the running 390 out, and installed a Built 300 with AOD.
Engine Video... http://youtube.com/watch?v=2xgYd2u79NU
- willowbilly3
Which is better for the typical street engine?j41385 wrote:What hasn't been asked, unless I missed it, is this... Is it an offy c or dp?
- danno
It is a DP intake,and I want to thank you for your help,this is a great wed site
Here's mine.
