300 six stuff
- heviarti
300 six stuff
I just pulled the 300 that has been spewing oil from god-knows-where at above 45 MPH, and replaced it with a marked up over stock 300 my buddy gave me. After fighting with it a long time to determine why I had a miss on number four, i decided the exhaust valve has recessed itself into the head.
If someone has their magic ovaltine ford decoder ring handy, is there some way i can determine what year the engine i pulled was? It's got various random crap on it, so I doubt it's a '70 like the pickup, but I have my doubts as to wether it's got stelite seats in it. (if not I'm just going to go find a 240 head....)
Also, does anyone have a full set of blueprint dimensions for the rods in a 300? I'm considering having some offset cap rods made, so when I rebuild mine it'll be ready to accept the supercharger.
- sideoilerfe
Re: 300 six stuff
Try www.fordsix.com They're all about that over there.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
Re: 300 six stuff
Mine does the same thing,after a while,it will start to miss on the second and third cylinders,starting from the front,I just change the plugs,and alls well,Im rebuilding another 300-6,to drop in,so its no sweat,Im porting the head myself.
94 Ford F-150 super cab
300-6 eod auto,changing to NP-435
- heviarti
Re: 300 six stuff
Here's the nasty trick to discover if you have the same problem as two out of the last three 300s i dealt with had. Pull the vavle cover. pull the rocker arms. if you can't see the difference, take a machinist's square and set it level from the top of the valve to the sealing surface for the vavle cover gasket. check the height of the exhaust vavles. if you've got one (or more) that sit high, there's your problem. they recess into the head and the motor will run like crud, and not tune up no matter what you do.
I registered for the ford six forum. I'm still waiting on my confirmation.
- willowbilly3
Re: 300 six stuff
I registered there a couple months ago and had to hound the adm several times before I got my confirmation.
I also had a 300 pound out the valve seat on a rebuilt 72. I had even asked the builder and he said don't worry about it. It ruined a head I had spent a good deal of time in porting. I think hard seats started in 73 but not real sure.
- heviarti
Re: 300 six stuff
head in mine is a '74.
I might have some trouble hounding the admin of that site, if he doesn't have contact info somewhere.
- willowbilly3
Re: 300 six stuff
If you google Fordsix you can get a coverpage that nonregistered used can see. They have contact info at the bottom of the home page. Right now the site seems to be down and emails to the adm. bounce.
BTW, what is "marked up over stock"?
Re: 300 six stuff
Here is what I could find:
Reason: Removed email and replaced with image of email to keep "web crawlers" away.
- willowbilly3
Re: 300 six stuff
that doesn't work. Sift around and find an address for 46ford something, that is the guy who will respond.
- heviarti
Re: 300 six stuff
hopped up? hot rodded? just a mite heavier duty?willowbilly3 wrote:BTW, what is "marked up over stock"?
- willowbilly3
Re: 300 six stuff
I figured that's what you meant, just never heard that term used, are you from England? sounds like a term they would use.heviarti wrote:hopped up? hot rodded? just a mite heavier duty?willowbilly3 wrote:BTW, what is "marked up over stock"?
Anyway, let me know if you got in a fordsix, I found the good email address that got me in after the hounding. You really need to be there if you are building one.
- heviarti
Re: 300 six stuff
No, Not a scone-head. I'm from Idaho. I've been away a bit, as I have been working on the ranch. I haven't been to town, seeing as I blew the third gear out of my bmw, in addition to the fourth i already blew. Stupid ZF transmissions. In my absence I also took some time to go and jack my flatbed dodge back from the folk who were holding it hostage. (I was losing sleep over it) Still no dice on for six forums. methinks it may be time for a new moderator who can differentiate his alimentary canal from an irrigation canal.
- willowbilly3
Re: 300 six stuff
I'm not sure why the hassle to get signed up but you can still read all the stuff and the FAQ in the 300 section has tons of good advice.
Pmed you the address that I used to get attention
Re: 300 six stuff
300 rodspecsheviarti wrote: Also, does anyone have a full set of blueprint dimensions for the rods in a 300? I'm considering having some offset cap rods made, so when I rebuild mine it'll be ready to accept the supercharger.
Length 6.2082-6.2112
Rod journal 2.2750-2.2758
Pin hole.9734-.9742
twist .012
Bend .004
Clearance .006-.0130 side to side
Wear limit .0180
Rod to crank bore taper max .004
From the 1971 Engine Manual
Ford did not put hardened seats in until 1976 and then not in all engines.
