390 miss fire
- mrtleavitt
390 miss fire
Cylinder #4 on my 390 has a small missfire. The pushrods are all good and the Edelbrock cam and lifters were installed maybe 10,000 miles ago. All new plugs, wires, cap, and rotor and the problem wasn't fixed, so I figured it's probably either the rings or something in the heads. I pulled the spark plug and it was a little more black than the rest but it wasn't wet. If my rings were worn there should be oil on the plug right??? So I'm thinking it's probably a valve that is messed up a bit. Is my reasoning on the right track or is there another factor that I might be missing?
Re: 390 miss fire
Yup. Compression. Do you have any. If not wheres it leaking? Sunk valve?
- fomocoguy
Re: 390 miss fire
Either buy or rent yourself a compression tester (if you don't have one) and check it. Then sqiurt some motor oil in the cylinder and check it again. If it goes up significantly, rings. If it stays the same, valve. Check all your cylinders while your at it to be sure it's low in the first place.
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
2005 Ford Ranger
- mrtleavitt
Re: 390 miss fire
Ok, I checked all the cylinders and they all checked out ok, about 130 for all of them. What else could I look for? Cam and lifters is all I can think of now, right?
Re: 390 miss fire
But what was the difference between the wet and dry tests? Since you've got an oil-fouled plug, we need to figure out where it's coming from.
- mrtleavitt
Re: 390 miss fire
It's not an oil-fouled plug. It looks like it's just not burning all the gas in the chamber. The wet/dry test was fine. Plus my exhaust is really gassy smelling and I used a emmision diagnostic tool at my brother's shop to adjust my carb so I know that it's tuned well. So it's definitly something with not burning enough of the gas.
Re: 390 miss fire
You got compression, ok. Maybee theres a vacumn leak thats making that cylinder missfire. Like a hose/gasket leak.
Also, make shure that the spark is going to the cylinder. Take the plug wire off, stick a screwdriver in the boot and lay it
on top of the motor. Run it and see if it makes sparks. Also, could just be a bum plug. It happens. Jake
- mrtleavitt
Re: 390 miss fire
Thanks for all the advise guys. I can't find any vaccum leaks, plenty of spark getting to the cylinder (have an MSD box), on my third plug now and still the same. I'll probably just bite the bullet this coming week and tear into the motor to check out the cam, lifters, and heads. It's due for some new gaskets anyways.
Re: 390 miss fire
Before you do that, why don't you invest in a set of plugs that are one heat range higher?
http://www.ngksparkplugs.com/techinfo/s ... country=US
- mrtleavitt
Re: 390 miss fire
Do you know one heat range higher in motorcraft for the sp420? I was figuring if my multiple spark discharge MSD ignition can't burn the extra fuel then a hotter plug probably won't do it. It's getting a great initial spark then about three smaller ones in between each major spark. I was doing some research and I don't think a hotter plug would do it. The main idea for a hotter plug it to keep it from fouling, and that's not my problem.
Re: 390 miss fire
Try this. Swap the plug from another cylinder and see what happens. Quick & easy.
- mrtleavitt
Re: 390 miss fire
Already done and no change. My bros 390 works great so I swapped his plugs and wires and no change in performance.
