Can spark plug wires rest on a heater hose?
mrtleavitt
Post by mrtleavitt »
I have some MSD spark plug wires that are resting right on top of the heater hoses that enter into the cab. Will wires be okay with this kind of heat or do I need to relocate them some how?
smclaren
Post by smclaren »
Should be OK ... both are insulated and the heater hose is not conductive.
Image Steve - Caloundra, QLD, Australia Image
1969 F100 4x2, RHD, Base Model, 240ci, 4sp, Dealer Canopy, No Bloody Radio.
Thunderfoot
re: Can spark plug wires rest on a heater hose?
Post by Thunderfoot »
:yt: and the heat is not a problem... if they were resting on the exhaust then that would be a problem, but the heater hose will not have enough heat to effect the spark plug wires.
Shayne
rubiranch
Post by rubiranch »
Heater hose contains carbon and carbon is a conductor. If the plug wire insulation wears thin voltage will leak to the heater hose.
I would not let your wires rest on the hoses.
:2cents:
smclaren
Re: re: Can spark plug wires rest on a heater hose?
Post by smclaren »
rubiranch wrote:Heater hose contains carbon
mrtleavitt, I will defer to rubiranch greater knowledge of heater hose construction.
I always thought they were rubber or something like rubber .. :? If you keep your ears and eyes open, you learn something new everyday ... :thup:
1971ford
Post by 1971ford »
what about garden hose :D
seems alot of our truck's heater hoses have been replaced with garden hose.
-Ryan
BobbyFord
Post by BobbyFord »
rubiranch wrote:Heater hose contains carbon and carbon is a conductor. If the plug wire insulation wears thin voltage will leak to the heater hose.
:2cents:
Water inside the hose is also a conductor. I have seen plug wires arc to heater hoses in the dark.
