Bulb chart.
Bulb chart.
Anyone got a list of bulbs needed for a 72. Most of the commercial sites are confusing.. there'd be like 42 bulbs if they are right.
Im assuming 1157 and 194?
Looking to not tear it apart twice.
70shortbox
Re: Bulb chart.
Post by 70shortbox »
1970 F100 Custom Shortbed Styleside
460/C6
Re: Bulb chart.
Awesome,
I looked, just not that section.
Thanks!
Re: Bulb chart.
You need for a 1972 anyway:
7" round headlights
1157 Amber for the front turn signal/park lights
1157 Red for the Rear Brake and Turn
1156 White for the Reverse Lamps
194 For the bedside markers.
When possible using LEDs you should use a bulb the color of the lens over it.
The only gotcha is that you need a LED compatible flasher with a polarity reversing adapter (or make jumpers to reverse polarity)
