Well, I finally have my engine torn down and sent off to the machine shop. They’ve already tanked and magnafluxed the C8AE-H heads, and...they’re cracked. Both of them. Into every single spark plug hole...
Oh well. Time for a more fun topic. I was chatting with the guy and he was saying he probably wouldn’t go bigger than a 204/214 @ 0.050 cam in this motor. I had my heart set on something like a Comp 268H, which is 218/218 @ 0.050 (0.494 lift with the stocker rocker assemblies). Is this a big difference? I’m pretty green to engine building so I’m not entirely sure what to expect. Like I said, it’s going into an F250 so I want good low end, but I also want a hint of lope (not a lot, just enough to make me grin
What say you? Another quick thing, he usually uses cams from Melling or someone like that; says they’re pretty much the same as, say, a Comp, which I can see if the grind is the same. So is it stupid to still want a Comp, or a Lunati, or something...name brand...like that? If only for the stickers
Appreciate the help!!
Edit: Some more info...
See sig. 3.73 rear end, 235/85r16 tires (may change to 265/75r16, but they’re pretty much the same diameter), T18 transmission (may swap in a TKO-500 or 600 eventually, as shekels allow), will have an Eddy intake manifold and a 4bbl when all is said and done (carb size TBD; thinking a 600 w/ vacuum secondaries would be fine). Will rarely, if ever, use it to seriously tow, despite the 8100lb GVW; will primarily be a cruisin’ and bruisin’ truck.
