Engine Gasket Question
Idaho Chris
Post by Idaho Chris »
What is this gasket called on the driver side on the 300 I6 engine? Any recommendations on where to purchase this gasket (and the bolt rubber washers) separately from an entire engine gasket kit? Thanks!
-Chris
1969 F250 4x4 4spd 300 I6
1973 Mustang Mach 1 351C
colnago
Re: Engine Gasket Question
Post by colnago »
Is that the valve cover gasket? Your best bet is probably your local AutoZone, NAPA, etc. If not, then check with Rock Auto, LMC Trucks, or NPD Link. Finally, Amazon or ebay.
Joseph
Idaho Chris
colnago wrote:Is that the valve cover gasket? Your best bet is probably your local AutoZone, NAPA, etc. If not, then check with Rock Auto, LMC Trucks, or NPD Link. Finally, Amazon or ebay.
Joseph
No, not the valve cover gasket. It is on the side of the block below the head behind the distributor. I am presuming it gives access to the lifters, but since I have never seen a 300 apart I do not know. If I can figure out what to call it I can search for a gasket...
-Chris
phantomtruck68
Post by phantomtruck68 »
They are called the push rod covers. Autozone part # PS10603C.
Joe
My Phantom truck
1968 F250 4x4
390 FE, bored .030, Crane 272 cam, 600cfm Edelbrock carb.
Idaho Chris
phantomtruck68 wrote:They are called the push rod covers. Autozone part # PS10603C.
Thank you Joe! I knew they couldn't be called Lifter Covers since my search with that term yielded zilch...
-Chris
phantomtruck68
Not a problem. Just passing on a little knowledge left in this noggin! LoL.
Joe
My Phantom truck
1968 F250 4x4
colnago
Post by colnago »
This is why I love this group; I am ALWAYS learning something new.
Joseph
jzjames
Post by jzjames »
When you re putting in the new gasket and donuts, be sure to “eyeball” the side cover for flatness. They can get distorted from over tightening and a little careful “massaging” of the cover to get flat and true can go a long ways to prevent any leaking.
