1969 highboy boxwood green
Lone Ranger
Re: 1969 highboy boxwood green
Post by Lone Ranger »
1guydude wrote:hows the truck man? Did u get monster tractor tires for it?!
lol
...seriously.
-d
No tractor tires for it yet haha. Sorry it's been so long for an update. I threw my back out pretty bad so I've been kinda laid up and working around it. Mostly tinkering with little things. I did run my valve cover exhaust over board( I kept getting oil in the air cleaner) not sure if I need vacuum to make it work so we'll see once I start driving it in the spring.
I also got my new heatercore in. Really a pain hunched over and twisted up under the dash but I got it done even with a bad back just took forever :lol: I also had to kick out the riff raff!
Kyle
Bullitt74
Post by Bullitt74 »
Ah rodents...those buggers seem to always find their way into the nice stuff! Are they new or old/deceased occupants?
Great to see you posting again Kyle! :thup:
Lone Ranger
Bullitt74 wrote:Ah rodents...those buggers seem to always find their way into the nice stuff! Are they new or old/deceased occupants?
They moved down south where it's warmer long ago-
Kyle
cdnwillyg
Post by cdnwillyg »
Smart creatures, wish we had gone south this year too! -35*C WC this morning, who needs that :eek:
1968 Mercury M250 Camper Special
FE-390,570CFM 4bbl, C6 Automatic, PS, PB front disk.
Stony Plain, Alberta, Canada
:drive:Willy
Lone Ranger
Ok I've got a question for all you guys who have done the 3G swap- I am currently making 14.8 volts with my new alternator with no lights on and I'm wondering if that is going to ruin my battery? I've only put maybe 400 miles on it since the 3G swap and everything still seems fine. 14.8 just seems like to much to be dumping into a 12 v battery.
Kyle
Manny
Post by Manny »
14.5 i perfect 14.8 no massive worry. Go past 15.15.2 then start worrying. My highboy two weeks after i bought it got home one night. Heard the battery sizzling after turning the truck off. Checked mine it was full yield 61 amp alternator regulator stuck. steady at 16.3volts......
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
Lone Ranger
Cool thanks Manny! It's just nice to know it won't blow up and leave me stranded somewhere.
Kyle
hfdco4
Post by hfdco4 »
Any updates Ranger?
:fr: FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
Lone Ranger
Sorry everyone I've been pretty busy. I spent all winter getting my fire 1 and 2 certs and also my emt license. I recently switched jobs and now am a full time firefighter. I'm still learning a lot but once I get more settled in I should have more time to work on the truck. It's been a lot of work to get to this point but I'm loving my new job!
I don't have any big updates on the truck just been driving it as much as I can and adding things to the list of projects it needs/wants. Still runs and drives like a dream. It drives better than my daily driver now.
Kyle
hfdco4
Post by hfdco4 »
Congrats on the certs buddy. I know that is a lot of hard work. Fire fighting is not for the meek, you will hate the job at times but will find it rewarding! :fr:
:fr: FE390PC
1970 F250 4x4
popeyes71
Post by popeyes71 »
:yt: Congrats on the new job and the accomplishments! Hope to see more of your truck in the future! :thup:
-Popeye-
1971 F-250 4x4 Highboy
Lone Ranger
Quick question for you guys. My transfer case is leaking pretty bad as of late and I've got a couple options. Buy the rebuild kit or buy a used transfer case. I'm contemplating the NP 205 upgrade and am wondering if it is a direct bolt up. Would i need to change drive shafts or change mounts? I'm curious how easy of a swap this is and what I would gain from the swap. How much work is it to actually rebuild a transfer case?
Kyle
Manny
Post by Manny »
Lone Ranger wrote:Quick question for you guys. My transfer case is leaking pretty bad as of late and I've got a couple options. Buy the rebuild kit or buy a used transfer case. I'm contemplating the NP 205 upgrade and am wondering if it is a direct bolt up. Would i need to change drive shafts or change mounts? I'm curious how easy of a swap this is and what I would gain from the swap. How much work is it to actually rebuild a transfer case?
Dana 24 is just like a dana 20 5 hours for me just a rebuild for a detail deal of course longer. They are not bad rebuild kits at Less than $200. Get one from broncograveyard, and new mounts you'll be set. If your keeping the six then you should never hurt a 24. A 205 will go in without major headache but i don't know if you fully need it. You have multiple options as always. :thup:
Bullitt74
Post by Bullitt74 »
Lone Ranger wrote:Sorry everyone I've been pretty busy. I spent all winter getting my fire 1 and 2 certs and also my emt license. I recently switched jobs and now am a full time firefighter. I'm still learning a lot but once I get more settled in I should have more time to work on the truck. It's been a lot of work to get to this point but I'm loving my new job!
Congratulations man! That is exciting!
Just don’t leave any more rattle cans on top of the furnace - the guys at work won’t let you live that down :lol:
Steve F.
Red Deer, Alberta, Canada
'72 Ranger XLT, 4x2, 390-2V, C6, Wind blue & Wimbledon White (‘Smokey’)
8)
2016 F150 Lariat FX4 Supercrew, Ruby Red
Follow my build thread for 'Smokey': http://fordification.com/forum/viewtopi ... 22&t=85070
hfdco4
Post by hfdco4 »
So what did you decide to do with the Transfer Case? The Dana unit is a good one and finding a divorced 205 at a reasonable price may be tough.
:fr: FE390PC
1970 F250 4x4
