I got her for scrap value, so not too bad. She does run. I've noticed that the truck has a lot of options you may or may not be familiar with:
One side of the cab is air ride:
While the other side has the optional organic ride.
She also has the optional organic hood support.
Plus the ever popular rustic, black over green paint job.
Also note the very low profile air cleaner.
It is equipped with a 1973 (according to the valve cover sticker) 390 (checked stroke with the rod in the sparkplug hole) mated to a c6.
Note that the bumper guards are left loose in order to line up best with the airflow in order to cut resistance, another option
This will be a slow build going from the frame up. She does run and pretty well actually. Thanks in advance for the questions you'll answer for me. Great site by the way.
David
