for anyone doing a resto!!! rust removal!!!!
Re: for anyone doing a resto!!! rust removal!!!!
yeah but how you going to do electrolysis on a hood??? or even finders??? I thought that only worked on smaller items.
- 390Nut
aahhh, watch and learn grasshopper. Anything is poosible with the right amount of creative ingenuity. follow the two links i posted in the following thread, particularly the second link.
http://www.fordification.com/forum/view ... =7&t=58807
Have fun either way you decide to go.
`69 F100 390 4spd driver
I can't go to the links in the other form because i'm at work(blocked) damnit! I'll check it out when I get home. Not going to lie electrolysis kinda scares me a little bit. electricity and water...
but thanks for the tip. I got most of the front end off her this weekend, with with over a 40yr old truck ever bolt is a battle... takes a long time. This isnt what I'm used to either, I used to work on imports a ton.
- 390Nut
Thats why you turn the power off before you get near the water.cboogie23 wrote:Not going to lie electrolysis kinda scares me a little bit. electricity and water...but thanks for the tip.
I can understand that, having worked on my own `69 quite a bit (as well as other old vehicles). You got to admit though there is a LOT more room to reach stuff on your truck.with over a 40yr old truck ever bolt is a battle... takes a long time. This isnt what I'm used to either, I used to work on imports a ton.
- averagef250
Maybe not in Yakima, but most larger cities have commercial metal cleaning outfits. If you're looking at spending several hundred on a big messy very high maintainence, very labor intensive pool why not just pay a fraction of that to have your parts proffessionally cleaned?
- flyboy2610
One important point regarding electrolysis: Dry the parts very thoroughly and get some paint immediately. They will rust in no time at all after having been electrolycized. (?) If the part is all metal you could dry it in the oven, then paint it.
Red Green
you'd better be right.
Red Green
