I know that I have seen it on the forum before, but.........
I was hoping that someone could help me to get an idea of the best way to remove my heater assemby to replace the core.
Thanks
Heater Assembly Help
1972 F250 Custom: 360 V8, C6 tranny, camper package with disk brakes.
re: Heater Assembly Help
Here's the thread I believe you were looking for:
http://fordification.com/forum/viewtopic.php?t=5561
Great! Thanks. I got the heater box off and am in the process of getting the core out. One more question......the heater wasn't hooked up when I purchased my truck and the previous owner had simply looped one of the hoses back into the block. My question is....what hose gets the valve? Is it the hose closest or farthest from the engine?? Any help would be appreciated. I have seen pics with it attached on both. Just wanted a clarification as to which one had the valve attached from the factory.
Thanks again......
Thanks again......
- granitestate68
Hi 2Tone,
My 68 has the valve on the hose closest to the engine. Hope that helps.
Lee
Lee
http://www.fordification.com/galleries/ ... p?pos=-550
1996 F250 Slightly lifted 7.3L Diesel
1961 Falcon Ranchero 144 Inline 6
- flyboy2610
If he bypassed the heater, it was probably for a reason: like a heater core with a hole in it!
I would recommend replacing the heater core. Also paint any areas that may be starting to rust. Bondo makes a product called One Step, it's a rust neutralizing spray. I use that, after getting as much of the rust off as I can, then give it a coat of primer, then surface coat it. Por-15 works well, too.
Red Green
you'd better be right.
Red Green
