HEADERS
- lee_ford
Re: HEADERS
Header problems:
1. Higher engine compartment heat and noise unless you wrap them in insulation.
2. Better fuel mileage can be a problem if you are looking at a work truck and need tax write offs.
3. More power if you have a lead foot and are prone to tickets.
If you are asking about problems installing them. It depends on the motor. More info would be helpful.
My 1969 F100 Gallery
[Please note: A lot of what I write may be common knowledge to some of us. But for a new comer and even us at one time, somebody had to inform us that FIRST time.]
- XLT
Re: HEADERS
I have a 390 stroker in my '71. The exaust system is coming up soon. I was told that there is a problem with headers because they are prone to rust.
I don't need a tax deduction.
XLTrucks from my town
- lee_ford
Re: HEADERS
Most new headers are made of a lot thicker metal than the old days. Years ago I knew people who would run headers with glass packs and short pipes. When they shut down the engine at night the cold air would condense inside the headers and they always rusted quickly.XLT wrote:I was told that there is a problem with headers because they are prone to rust.![]()
This is why there is a market for ceramic coated headers. They will not rust.
All the other headers should be coated with high temp paint BEFORE you install them.
Here is an idea:
Spray the outside your color choice. Get another quart of any color high temp paint. Dilute the paint (75/25 or 66/33) with thinner so it will flow easy. Seal up the engine side with maybe some duct tape & plastic wrap and a header cap with gasket on the collector. Pour the mixture in and shake. Be sure to rotate the header so as to coat the inside of all the tubes. Use the collector to shift the paint from one tube to the next. Just like shake and bake. Just give the paint on the inside plenty of time to cure or you will be shooting flames from the thinner fumes.
- sport71
Re: HEADERS
Put the headers, the only problem is the starter having a tight fit, and put a heat shield on it.
DON'T BUY CHEEP HEADERS, YOU WILL ONLY GET WHAT YOU PAY FOR...
for the noise, the noise comes out the tail pipe, not in the engine bay. For the heat, I laid down some deadener. Other than that get some GOOD locking header bolts and gaskets...
Those who do not learn the lessons of history, are doomed to repeat it.
- lee_ford
Re: HEADERS
Not to be picky but, if you ever hear a car with headers and QUIET mufflers, you WILL hear the headers. You can also hear this sound inside the cab if it is not insulated well. I learned this street racing back in the 60s. My buddy put large quiet Caddy mufflers on a really hot motor to fool the competition. It is a very distinct sound and one you will not forget. I think I like that sound better than a load exhaust.sport71 wrote:...for the noise, the noise comes out the tail pipe, not in the engine bay.
- XLT
- lee_ford
Re: HEADERS
YES!!!!
- XLT
- lee_ford
Re: HEADERS
Here... 16 or 14 gauge,
http://www.stans-headers.com/ford_headers.htm
If you do not like Tri-Ys and want a four tube and for a little more money, these guys will make you whatever you want.
http://www.stainlessheaders.com/index.aspx
http://www.youtube.com/watch?v=pYYV5uVcdiU
Edit: If memory serves me correct, the Tri-Y headers are good for torque.
- XLT
- tybob81
Re: HEADERS
If you have to save up for a little longer do it!! It sucks having a leaky collector or flange to always mess with.
1968 swb hydroboost, ididit tilt column, Saginaw p/s pump with F series serpentine, all led lights, Vintage Air and painless wiring. 393w, tko600. CV front suspension w/c5 calipers and gt500 rotors. Stock Flexomatic leaf springs with 01 CV 8.8, 3.90 gears and Auburn locker. Custom wood bed floor. Full frame off resto-mod.
