smoking eng
hotrod ford
smoking eng
Post by hotrod ford »
bought this truck from a member awhile back. eng (I 6) is not original and plan on replacing it (V8 ). in the mean time i will use it (I 6) until the other is ready. the po wrote this in his ad " am going to say that one is NOT running because the last time I drove it it began producing LOTS of white smoke from the crankcase. The opening where you put the oil has smoke puffing out when you open it up. " . now he drove it on the trailer and off to get it to my house. what am i looking forward to when i get home to this truck? thanks :thup:
i was thinking it might be rings, valves or both?
Re: smoking eng
If the smoke is white that means coolant... blown head gasket or cracked block or head.
The puffing smoke out the valve cover sounds like a well worn engine, probably predominately rings, but valve sealing is probably a contributor.
Honestly, there are some things you can check, but the likely hood is that you are looking at an ovehaul.
1971fordcustom
Re: smoking eng
Post by 1971fordcustom »
Mines done that for the past two years! Im still driving it and its doin fine.
I'll put a 390 or go back with the 360 when get the $$
http://s205.photobucket.com/albums/bb31 ... d%20F-100/
1971 F-100 Explorer Special custom
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1960 Ford F-750 FireTruck
1960 Gmc 6000 FireTruck
1962 IH R-185 Firetruck
1959 Ford Custom 300
1940 Ford Truck
hotrod ford
Re: smoking eng
DuckRyder wrote:If the smoke is white that means coolant... blown head gasket or cracked block or head.
Here is what the po said when i asked him about it:
the truck had rust in the tank when I bought it. I replaced the fuel filter a few times and I was able to drive it without it clogging up.When pulling out the dipstick it looks really rusty. I should have cleaned it off and changed the oil before it started smoking really bad. It probably wasn't a very good engine to begin with. They said the engine came from a '79 econoline van. It was always easy to start with the manual choke. It was a lot of fun to drive even with the vibration.I'll try to think of more good or bad about the engine. It never leaked coolant while I had it. I don't recall having to add any water/coolant.
hotrod ford
Re: smoking eng
did some research on 1979 econolines. the only inlines that were available for them were 300's. if so, would there be some sort of off balance there that may be causing the vibration? and with the rust look on the dip stick, the chance of coolant in the eng, thats the reason for the smoke? maybe? :hmm:
sgs
Re: smoking eng
Post by sgs »
short story; Your engine is toast!
sgs
hotrod ford
Re: smoking eng
i'm thinking so too. the good is though, i bought the truck for the body. already getting parts for the 429. found a pair of mounts already and am waiting on an answer for some headers. :thup:
Re: smoking eng
i drove a 360 around for awhile like that. it pour smoke out the tail pipe eveywhere i went. i just kept pouring more oil in it. until one day i forgto to fill it back upand it locked up on me. now i have a 390 in it.
hotrod ford
Re: smoking eng
well, soon as i get home the truck is going in the garage and the motor is coming out.
