electronic ignition for 360
cooltoolguy
Post by cooltoolguy »
ok, so how much better is the ford electronic ignition than the "points" set up. More power, better economy? Since I cant sell my truck,(apparently there is not strong demand for 72 fords here :lol: ) I am still using it but it seems like it has no giddy up & go (been that way since i had it) but I have a '76 360 sitting in the garage with the factory electronic ignition (and not beat as hard) which is trying to convince me to put it in the old truck. I keep telling it NO, not until i know it is worth it. Sooo.. is it worth it?
72 Ford F-350, 2WD, 4 speed 360, Dump truck
76 Ford F-350, 2WD, Cab and Chassis <--gone
Re: electronic ignition for 360
i know it will save having to adjust the points more often. i don't know what it would have to do with economy. you wouldn't have to swap the engine just the dist and the wiring for it all.
FORD428CJ
Post by FORD428CJ »
cooltoolguy wrote:ok, so how much better is the ford electronic ignition than the "points" set up. More power, better economy? Since I cant sell my truck,(apparently there is not strong demand for 72 fords here :lol: ) I am still using it but it seems like it has no giddy up & go (been that way since i had it) but I have a '76 360 sitting in the garage with the factory electronic ignition (and not beat as hard) which is trying to convince me to put it in the old truck. I keep telling it NO, not until i know it is worth it. Sooo.. is it worth it?
Try using the search bar to find your answer..... Click on the link below!
http://www.fordification.com/forum/search.php?fid[]=3
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
sideoilerfe
Post by sideoilerfe »
If your truck has no get up and go, try advancing the timing to at least 10 before TDC.
basketcase0302
Post by basketcase0302 »
Had the Petronix in mine for awhile now, can't complain.
From the forum the "brain box" swap is pretty easy.
And should give you a hotter spark for more fuel economy.
My :2cents:
Dragon
Post by Dragon »
How heavy is that dump bed? My 69 F350 Flat bed dually weighed 6100 unloaded and with 4.10s and the 360 it was no race car but it ran good. It ran so good that the guy that had it before me hauled trees with it. One time he had to remove a stumps and could not pull it out of the ground. They hooked a F150 to the chain wrapped around the stump and dragged the F150 to the stump backwards while idling in first in the F350. The replacement 2100 autolite carb got better mileage but no better power than the original 69 rebuilt carb.
Ever replace the timing chain and check the mechanical advance?
mikeconner1
Post by mikeconner1 »
I would take a look at MSD. If you take the distributor out of that '76, you can use it with the MSD set up, and the stuff plugs right into the distributor. Not saying you wouldn't have to do some wiring, but its pretty simple. Firing that spark plug three times per compression is the stuff, and will give you a very noticeable pick up and improve mileage (provided you can keep your foot out of it, which I can't, if it runs fast, then so do I).
'40 pickup, '51 F6, '54 F100, '56 F600, '59 F100, '60 F100,
'64 Unibody, '64 F100, '66 F100, '66 Bronco, '67 Fairlane (wife's) '68 F100,
'72 F250 '72 F100, '77 F100 4X4, '83 F150 4X4, !944 2N, 1951 8N, 1952 8N, 1953 Jubilee
1960 881 Select O Speed, 1961 801, yeah I'm eat up with it.
Non-Ford: '41 Plymouth, '55 Desoto, '67 Jaguar 420, '72 Mercedes 220
'84 Subaru GL turbo coupe. I need more garage, maybe an empty Wal-Mart.
BobbyFord
Post by BobbyFord »
mikeconner1 wrote:I would take a look at MSD. If you take the distributor out of that '76, you can use it with the MSD set up, and the stuff plugs right into the distributor. Not saying you wouldn't have to do some wiring, but its pretty simple. Firing that spark plug three times per compression is the stuff, and will give you a very noticeable pick up and improve mileage (provided you can keep your foot out of it, which I can't, if it runs fast, then so do I).
Wiring diagram for Duraspark distributor using MSD 6 series box on page 31 of this PDF...
http://www.msdignition.com/uploadedFile ... t/WDTN.PDF
FORD428CJ
Post by FORD428CJ »
even a Mallory 6AL works good too. I have had both. Just a matter of opinion.....
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
FoMoCo
Post by FoMoCo »
I built my 67's 300 six with a durspark and MSD 6A. The truck was very powerful and reliable and extremly easy to wire. I went with the petronix stock replacment unit on my 69's 360. Never had a problem with it. I left it in the engine when I junked the old 360 :( I would recomend the petrox again and again.
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
george worley
Post by george worley »
I have a Mallory HyFire on my 390 ,still uses points but they last a long time. Only have adjust for point gap, simple hookup uses stock coil but must have 12 volts to it all the time,bypass resitor wire. Puts out a hot spark,will start a badly flooded engine. Have had on for over 18yrs. no problems
Dragon
Post by Dragon »
That was a fairly simple amplifier and by reducing the voltage from 12 to 3 volts across the points it did make the points last. As long as the rubbing block stayed intact. As the points opened a transistor dropped the 12 volts that it fed to the coil and the coil fired. Because a transistor switch is so much faster than the points switching it made for sharper rise times in the coil and longer dwell times. We ran the hyfire without the capacitor in the dizzy as it was not needed to tune to the coil.
But any points eliminator does the same thing without the mechanical wear of the points rubbing block.
