Freeze Plugs
ares360
Freeze Plugs
Post by ares360 »
I am taking apart the old engine and am going to replace gaskets, plugs, etc.
What is the best material to use: brass, steel, or rubber? or something else I do not know of? I am looking on autozone. :fr:
Kane
1971 Ford F250 4x2, no engine.....what am I going to do?
Dragon
Re: Freeze Plugs
Post by Dragon »
Brass resist corrosion better. Rubber freeze plugs I only use in an emergency until I can pull the engine and do it right. FEs use 49/64ths freeze plugs not the 48/64-3/4 plug they try and sell for them.
ares360
Re: Freeze Plugs
Post by ares360 »
they do sell 49/64 at autozone but the brass is 18$. and once again O'reilly is useless (as usual) about giving a proper description of something so they have 19 different one's but you don't know what they are made of....
Kane
Dragon
Re: Freeze Plugs
Post by Dragon »
ares360 wrote:they do sell 49/64 at autozone but the brass is 18$. and once again O'reilly is useless (as usual) about giving a proper description of something so they have 19 different one's but you don't know what they are made of....
O'Reilly just bought Checker and Checker got their 49/64s from Dormans. My 360 had steel ones and boy did they all rust out at about the same time, 10 years too soon.
ares360
Re: Freeze Plugs
Post by ares360 »
dragon,
you have any idea what the brass one's from o'reilly costs?
Kane
Dragon
Re: Freeze Plugs
Post by Dragon »
ares360
Re: Freeze Plugs
Post by ares360 »
thanks. :fr:
Kane
Dragon
Re: Freeze Plugs
Post by Dragon »
No Problem
Hawkrod
Re: Freeze Plugs
Post by Hawkrod »
Be aware that most brass core plugs are brass plated not solid brass. Good ones are brass but brands like Pioneer are simply lying to us. Take a magnet and check them and you will find almost all of the off brand brass ones are really plated steel. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
Re: Freeze Plugs
isn't that false advertizing on thier part?
BobbyFord
Re: Freeze Plugs
Post by BobbyFord »
I always brush a bead of Avaition Permatex (brown gunk in brush-capped bottle) on the band of the brass freeze plug prior to installation. It aids in installation as a lube and seals imperfections in the freeze plug bores.
Dragon
Re: Freeze Plugs
Post by Dragon »
That is a great idea and us Ford Techs did it that way. Fords manual says use a oil resistant sealer for the cam plug but we got in the habit of using Permatex on every expansion plug.
JEF199
Re: Freeze Plugs
Post by JEF199 »
Be careful I use brass plugs in marine engins because of salt water. But after 17 years I would say that 9 out of 10 blocks will bust before the plug pops!!
  • 1966 Ford Mustang (My First Car)
    • 1972 F250 360 3-speed
      • 1984 Bronco
      1999 Eddie Bauer Expedition
    2006 F250 5.4 Super Duty 4-door
ares360
Re: Freeze Plugs
Post by ares360 »
I will take a magnet with me when I go to the parts store...lol
:lol:
Kane
