What is the (actual) capacity of the cab mounted tank inmy
'68 F250 Camper Special?
I also noticed that when the cab tank is empty,& I've switched to
the "Aux" tank,that when I switch back,it will still run for a while.Is
this just residual gas from the "Aux" tank,or is it still gas from the
cab tank?
- Doug
Gas Tank Capacity/Transfer Switch
I like new things-
- when they're 40 years old!
Re: Gas Tank Capacity/Transfer Switch
19 gallonsangliagt wrote:What is the (actual) capacity of the cab mounted tank inmy
Yes, fuel that's still in the lines and carb.angliagt wrote: I also noticed that when the cab tank is empty,& I've switched to
cab tank?
Thanks!
- Doug
- Doug
I like new things-
