coil
- 03rangerxlt
coil
can somebody post a pic of the location of the coil on a 1968 Ford F100 360 v-8? Would greatly appreciate it.
-John
1968 and 2003 Ford Ranger
"Honey, how 'bout I lock you up on charges of aggrevated dumb slut with no future?"
-Det. Ray Carling "Life on Mars"
"Criminals thrive on the indulgence of society's understanding."
re: coil
Right next to the distributor
1969 Ford F250 Custom Cab 360/C6 - currently under de-construction
- Thunderfoot
re: coil
Here is one of mine from the side.
Shayne
- SteveC
re: coil
67s is mounted to the ac support bracket
http://s169.photobucket.com/albums/u223 ... 010049.jpg
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- 03rangerxlt
re: coil
awesome, thanks guys. i don't havemy truck handy to look at it. anybody have any pics that would help me identify if my truck is truly a 360, just from appearance?
-John
- SteveC
re: coil
unfortunatlly no the 352 360 and 390 all look the same from the outside
"The 360 and 390 blocks are identical externally. The only way of differentiating between the two, since there are no external markings to tell you what you've got, is to measure the stroke. Simply rotate the crankshaft around until the #1 cylinder is at TDC (top dead center) as indicated at the timing mark. Remove the spark plug and insert a wooden dowel into the cylinder until you hit the top of the piston and make a mark on the dowel. (Use the valve cover lip as a constant reference source.) Then remove the spark plug from the #4 cylinder (when #1 is TDC, #4 is BDC) and make another mark on the dowel. Then measure the difference. A 360 has a 3.50" stroke and a 390 has a 3.78" stroke. "
1967 f-100 4x4
1967 f-100 4x4
