Started up the F100 after 12 yrs (movie) - Christmas update
- My427stang
Well, spent some money the past few days
- New set of Jet-hot coated Hedman headers
- New Black crinkle Lemans FE valve covers
- New Chrome Ford air cleaner with hipo 390 sticker (LOL)
- New 750 Vac sec Holley
This week I detailed under the hood and painted the long block (its only got 10K on it), replaced the rear main seal and painted the oil pan, and cleaned the aluminum intake
Tomorrow I am going to clean up the wiring harness and make things a little prettier than they were
I am out scouting for prices to get the bed walnut shell blasted and epoxy primed while I put the Dana 60 and new rear springs in
Coming along well, more pics in a week or so when the engine compartment is finished!
re: Started up the F100 after 12 yrs (movie) - Christmas upd
Ross,
I am glad you got it running again.
Is that a 3 groove pulley you have in there? Thats the nicest one I have ever seen.
Hi, I'm Nathan and I approved this message.
1968 F250 LWB 360 (now 390) 4 sp High boy mine
1999 Expedition Eddie Bauer Edition 5.4 liter girlfriend and daughters
- cghstrojan08
Ya, need some pics please.1971ford wrote:sounds purty, but you forgot the pictures
ROBERT
Member #1076
1968 F100 SWB 360
1969 F100 LWB 360 "Ol' Blue" - Sold
1976 F350 Trailer Special, Extended Wheel base, 460
http://s9.photobucket.com/albums/a75/cg ... ld%20Blue/
Member #1076
1968 F100 SWB 360
- My427stang
OK, some pics, more to come on the truck
Here is the new carb, 750 vac sec
Here is one of the new valve covers
And another view. Needless to say the carb will be swapped and I am going to get the distributor looking good
I swapped the oil pressure sender and detailed the oil filter adapter just after this pic!
Jet Hot coated Hedman Headers are due here next week, I'll update with assembled and final detail underhood ASAP!
- basketcase0302
Same carb I've got on my boat, (but I have the marine version with electric choke).
I love that carb with the center-hung floats, and ease of working on.
Like the valve covers too.
Basketcase
Basketcase
- cghstrojan08
Lookin good.
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
- Manny
Hey i got two of them out of a 360 in a 75' amazing how the quiet down eh. Glad you got er going again always a triumphMy427stang wrote:One a custom on-of-a-kind corner-turnin pushrod
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- My427stang
Getting there
A few more pics
Waiting on my headers, didnt show yesterday, a different dual feed line, and a backordered repop Ford hipo air cleaner complete with "High Performance 390" sticker
Current air cleaner is temporary, and very ugly needless to say LOL
Still need to detail the lower steering column mount, change around how the heater hoses run, and run the brake booster vacuum hose correctly on the original tie downs to the cowl
man thats a good lookin engine. that air cleaner is a monster. will the hood clear the height?
- My427stang
I can go another 3 inches.
That filter used to be on the motor with a 1 inch nitrous plate, a Predator carb and a heat shield!
Matter of fact, years ago when I though it needed even more air I used to stack 2 of those filters with a drop down base
I am older and calmer now, just want a good running street truck, the Mustang is there when I really want to boogie
Looking great! Love the valve covers!
Was that spark wiring pre-made? If so, which it is it? Fits nice and I'm looking for a good set.
'72 F250 Ranger
Disk brakes, PS/PB, 360 2bbl
Current condition : beloved 'beater'
'70 F250 Camper Special
Currently in the shop, totally stripped
'72 F250 Ranger
- My427stang
No I cut them to length 15 yrs ago, however I rerouted them and you can see #5 is a little long, I am going to shorten it. Might even be time to change them
I also had to open all the stock Ford looms with a dremel to fit the 8 mm wires
- basketcase0302
Looks real nice!
Ones on my bump now are bout' that old, (had to take laquer to clean them enough to be "presentable").
Basketcase
And my wife thought I was the only one to keep old parts that long!15 yrs ago
Basketcase
