D44 gear lube question....
4x4 & Off-road Forum Archives
Moderator: Doug Comer
waynaferd
Post by waynaferd »
On the closed knuckles, I was changing the front brakes and there looks like a fill plug in the back of the knuckle.....does anything go in that?
I don't have a manual or anything so I figured I'd ask here....Thanks!!
A 72 F-250 Hi-Boy "project" ( that means sitting untouched for 3 or so years)
And a little 94 F-150 Flareside, 7" higher and 35's...
460 crew
re: D44 gear lube question....
Post by 460 crew »
I thought I had seen somewhere that you put a thick gear oil in them but usually the seals that swipe the trunion ball on the knuckle go bad or leak so most of the ppl I have known have just pumped them full of hi temp bearing grease.
heep70
Post by heep70 »
You can mix a slurry of bearing grease and gear grease then squeeze it in there. make sure your wipers are good. I just pack mine with bearing grease.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
montana_hiboy
Post by montana_hiboy »
those knuckle seals are notorious for leaking......i put a mixture of 140 wt gear lube and bearing grease in mine
