coil or relay?
Electrical and Wiring Forum Archives
oh i almost forgot you are suppose to put the negative cable on last. its also the first one your suppose to remove when taking the battery out. or even when working on the truck.
19674x4
Post by 19674x4 »
its really weird because i started it the day before with it in neutral and no clutch then i changed the alternator and went to start it up and no go. the only thing i can think of is the ground on the alternator is not grounding but i put it on the post that said GRD
My Photo Album
i think you can start an engine without the alternator. and i know you can remove the battery from a running engine. how did crossing the soilnoid do? anything?
19674x4
Post by 19674x4 »
i havent had a chance to cross the sylonoid, what two posts do i need to cross, the one from the battery and the one going to the starter?
My Photo Album
19674x4
Post by 19674x4 »
i disconnectd the neutral safety switch a long time ago. today i put a fresh battery in it and still nothing.
My Photo Album
you cross the battery side of the soliniod with the closest to the battery small terminal on the solinoid.
19674x4
Post by 19674x4 »
well i dun it but nothing happened- no spark or nothing, that usually means the solonoid is bad right? or could it be my negative battery cable. keep in mind i just replaced that alternator so let me know if i could have screwed up there to. the only other thing i have not done is checked the fuses underneath the dash.
My Photo Album
then its either the cables . the connections or the battery.
460 crew
re: coil or relay?
Post by 460 crew »
When ever you replace an alternator it's a good idea and recommended to change out the voltage regulator. I recently had some starting problems and ended up replacing an ignition switch, started solenoid, Alt, battery and coil. Ended up my problem was the positive wire on the Alt was breaking apart and was only making contact on vibrations, in turn it wiped out my voltage regulator and killed the Alt. When I replaced the alt and no voltage regulator it overcharge my fairly new optima and blew acid all over my engine compartment. So back to the store for a voltage regulator and a new red top. lesson learned. Like stated above check your connections even where you have factory connectors for decaying.
19674x4
Post by 19674x4 »
i changed the vltage regulator.
My Photo Album
did that fix it?
19674x4
re: coil or relay?
Post by 19674x4 »
i get a dunce cap :oops: i had my battery cables on the wrong posts, no it starts fine :shh: :cry: :oops: :o :( :eek:
My Photo Album
