Starter Question
Starter Question
I am having trouble getting my starter to kick over. it seems i am geting power to the sylinoid but for some reason i am only getting juice to half the terminals on it and there is no juice running down to the starter.
Basicly turn the key no juice it is like the battery is dead but is has a charge.
Are ford Starters Self Grounding? Do i need to have a ground lead to a bolt some where?
Frustration builds.....
Thanks
Thanks
- 68F250
re: Starter Question
Yes, the solenoid gets it's ground from the mounting bolts.
Pull off the wire on the "S" terminal and take a jumper from the battery side to the "S" terminal, see if she turns over. It's been awhile but last time I did this I was able to use a screwdriver and crowbar the two together.
Re: re: Starter Question
Thats kinda what i thought i have some wierd starter from a toyata or something that has been converted to fit with an aluminum adaptor i think that is causing my problem but i don't really know. i was told this would help save my flywheel because it was suposed to create less stress on it. i guess ill have to buy a new Starter that is suposed to be in there eh... oh well... I hope it will work as i have a very old starter that is the original but it seems to have a broken post where the Red wire from the Solenoid comes down and connects to the starter. I can even get that one to work.68F250 wrote:Yes, the solenoid gets it's ground from the mounting bolts.
(I hold the hot wire there,No go... No Juice No Gound? i just do not get it!
A question to anyone, (I assume the wireing is stock) in connections to the sylinoid i have a caped brown wire and a capped Red/blue wire what one goes where please? I have posts labled I & S68F250 wrote:Yes, the solenoid gets it's ground from the mounting bolts.
Black 1971 F250 Sport Custom 390 Engine.
I have no idea what i am doing please help me!
Seriously,I just bought this for 500 Bucks and some tools from Kmart. I Have very Little Auto Experience. Any Advice is needed. I have to make it run...
- hardtailjohn
My 70 has a brown wire to the "I" terminal and red wire to the "S" terminal on the solenoid.
John H.
John H.
Ahh thats what i got too brown to the I and the red/blue to the s.hardtailjohn wrote:My 70 has a brown wire to the "I" terminal and red wire to the "S" terminal on the solenoid.
John H.
I tried bridgeing the 2 and all i get is a lite spark off the s post and still i have not heard the starter try to crank over.. i even wire brushed all the places i thought might help ground it but no luck. why dont i get power i wonder? Maybe my Battery is the issue but i just had it charged up.I have power and get a clicking sound when i turn the key on and off i just dont get no Starter function... What am i missing i wonder...
- hardtailjohn
Put a volt meter on the starter side of the solenoid and see if you get full voltage through there... that will at least tell you what direction to go. If there isn't full voltage, then check ahead of the solenoid. If there is full voltage going through, then check at the starter. If you have full voltage to the starter, then you have your problem.
As far as a ground, you can use an ohm meter and check from the starter case to the engine block.. no ohms means good ground. If the starter's loose or has been loose, that's a good place to start checking.
Electrical can be overwhelming, but it's not that bad if you just start at one end (or somewhere easily accessible) and work from there.
John H.
John H.
- 68F250
No, don't bridge the two little posts! Jumper the battery side of the solenoid (where the battery connects) to the little "S" terminal. Pull off the wire on the "S" terminal and let it hang. Use a short piece of wire or a screwdriver to jumper the "S" terminal on the solenoid to the battery terminal of the solenoid. Make sure you're out of the way of the engine. Sorry I wasn't clear.swschulke wrote:thats what i got too brown to the I and the red/blue to the s. I tried bridgeing the 2 and all i get is a lite spark off the s post
Barry
Ahh well that makes a loud clicking sound that sounds like it is in the solenoid. the starter did not try to turn the engine though.... It is more then i have been able to do so that is something new...68F250 wrote:No, don't bridge the two little posts! Jumper the battery side of the solenoid (where the battery connects) to the little "S" terminal. Pull off the wire on the "S" terminal and let it hang. Use a short piece of wire or a screwdriver to jumper the "S" terminal on the solenoid to the battery terminal of the solenoid. Make sure you're out of the way of the engine. Sorry I wasn't clear.
- 68F250
Did you get the new starter yet?
Starter gets its ground from mounting onto the engine. Make sure the starter flange has bare metal where it mates to the engine. Rebuilt starters have the flange painted gray to look pretty but act as an insulator, I always file the paint off.
Barry
ahh yes i did a bit of wire brushing to all the spot where the Wierd starter Touches. still no luck, A Shame as it is suposed to help save the flywheel.68F250 wrote:Did you get the new starter yet?
No New Ford starter yet Looks like Wendsday a friend is gona to loan me a few buck to help off set the cost of it...i am guessing like 50- 100 dollars with the core(Wonders if i can use the Wierd Toyata one)...
- 68F250
While you're waiting, wanna check out that starter? Pull it off the engine (I know, a pain) and set it on the ground. Get some battery jumper cables and hook them up to the battery. Take the other end of the negative cable and clamp it to the starter flange. Then take the other end of the positive cable and touch the positive post on the starter. Be careful, the starter may want to jump, hold it down with your foot. Watch out for sparks too.
Barry
- willowbilly3
If you have one of those starters with a solenoid on it you have to run another wire from the old solenoid to activate it down there. I'll have to think about it but I put a permanent magnet starter on my 72 and it came with the directions. I think that wire went under the big cable that goes to the starter.
Well what i ended up doing ws buying a new starter and a new battery. allthough i still was not able to get it to turn. i am starting to think i missed something...willowbilly3 wrote:If you have one of those starters with a solenoid on it you have to run another wire from the old solenoid to activate it down there. I'll have to think about it but I put a permanent magnet starter on my 72 and it came with the directions. I think that wire went under the big cable that goes to the starter.
oh well...(Looks up junkyard numbers for reference hehe)
- Mohillbilly
Another thing to check is the ground from the body/chassis to the engine. If the engine isn't grounded good, it will cause the exact thing you're seeing. If you tested the starter off the truck and it spun, then a bad ground is a probability.
70 Custom LWB, 302-2V, 3 on tree
