Coolant under valve cover.
Gmcarolina
Post by Gmcarolina »
I bought this 1967 F100 with a 352 fe engine from a friend of mine about 3 years ago .This truck sat for about 8 years got it running like sewing machine . I wanted to clean up the engine do a little detailing to it . When I taken off the valve cover I noticed small amount of antifreeze in the oil . I started it up and watched it and every once in awhile little beads of antifreeze in the oil . The oil looks good and the antifreeze looks clean I'm thinking intake gasket I hope. The 352 is still stock with about 47000 miles on it.
Re: Coolant under valve cover.
Most likely source is intake gasket.
All the other possibilities i can think of are cracked something.
Id change the gasket first. its easiest even with 80 lb manifold....
Gmcarolina
Thankyou for your reply. I was thinking same thing I just want to make sure before I dig into it. I've got a set of intake gaskets I guess that'll be a project for the fall when it cools off in the garage.
ddcrim
Post by ddcrim »
My guess would be head gasket.
Gmcarolina
I started replacing my intake gasket . I've gotten all the mating surfaces clean what a job bending and stretching going to be sore tomorrow. There's no way I'm going to lift that intake back in like I taking it out earlier today. When I put intake gasket on the heads does the print side faces the intake ? I stop for the evening. I'm going to dig out my cherry picker to install it. Hope everything goes good.
What gaskets do you have?
Gmcarolina
Fellow intake gasket. They are blue with a grove around each opening.
Gmcarolina
Spell check it's fel pro gasket
Gmcarolina
Spell check fel pro gasket
Gmcarolina
Fel pro intake gasket. They are blue with a grove around each opening.
if they are "print o seal" use different ones. Just the plain ones.
Been a while but i t think it didn't matter on the last set i used...
Check out lykins motorsport you tube he has a "how to install an fe intake video i think...
Gmcarolina
Ok thanks , I've got to go napa tomorrow morning I'll see what they have for intake gaskets. When I bought the truck it had a brand new set of fel pro gaskets under the seat it doesn't say print o seal anywhere on the box or on the gaskets. But I guess the grove around each opening that's what it is.
1247 is the print o seal.
90145 is the plain one.
Gmcarolina
Ok I'll check in the morning
