390 motor
- tdsmoonchild
390 motor
Having trouble finding a 390 motor to rebuild around here. If you have one laying around or know where I can look, give me a shout
Re: 390 motor
Have you ever thought about a 390 crate engine? All of the work is done and the cost probably would be less
- redstone65
Re: 390 motor
What's a trusted source for a 390 crate?Mach428 wrote:Have you ever thought about a 390 crate engine? All of the work is done and the cost probably would be less
- redstone65
Re: 390 motor
Interesting. Thanks. Didn’t realize they still carried FE crates.
- urchinhead
Re: 390 motor
They don’t. Check out the FE Forum.
1970 F100 Custom 2WD, SWB, 360 FE, np435
1964 Galaxie 500 Convertible, 390, Cruise-o-Matic
http://i171.photobucket.com/albums/u309 ... fa6562.jpg
Re: 390 motor
https://www.summitracing.com/parts/vre-df19/urchinhead wrote:They don’t. Check out the FE Forum.
Re: 390 motor
https://www.summitracing.com/parts/vre-df19/redstone65 wrote:Interesting. Thanks. Didn’t realize they still carried FE crates.
Re: 390 motor
I don’t know how great those VEGE engines are, there are quite a few folks that will build you a motor though... Brent, and Barry to name 2 then there is I think Brett... Oh and of course Ross...
Do you have a 360 now? because if so you only need a 390 rotating assy... or a 410 rotating assy or a 445 rotating assy...
