Sons F250 project
Sons F250 project
Well I figured I would start this thread to post the updates on the truck. They have been getting quite a bit done lately with less snow days at school. Here are few pictures of the progress this last couple weeks since we joined the site. They did the body work on the hood have it in primer, done most for the sanding on the cab and removed the bed today to start the cab corners tomorrow. More updates to follow!
Re: Sons F250 project
Couple more pictures
- cdnwillyg
Great father son project, keep us posted. Nice facilities to do the work. Looks like a solid truck to start with also.
Stony Plain, Alberta, Canada
:drive:Willy
:drive:Willy
- popeyes71
Good progress. I'm looking forward to seeing how she turns out!
-Popeye-
1971 F-250 4x4 Highboy
- Bullitt74
Steve F.
Red Deer, Alberta, Canada
'72 Ranger XLT, 4x2, 390-2V, C6, Wind blue & Wimbledon White (‘Smokey’)
2016 F150 Lariat FX4 Supercrew, Ruby Red
Follow my build thread for 'Smokey': http://fordification.com/forum/viewtopi ... 22&t=85070
- Manny
That's great they are getting it done and learning can't wait to see more.
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
Update! They have the cab corners cut out and they have done a little rebuilding on the rockers this week! They took the gas tank out and are preping for a tank relocate, Mustang tank under the bed in the rear! I also did a little horse trading with and extra set of steal wheels I had laying here from my 02' F 250 and got him a set of 97' F 250 aluminum wheels! To say they needed a little TLC would be an understatement! But after stripping them of the stupid clear coat and doing a lot of sanding and polishing they should be ok! But trying to find a set of factory center caps for these wheel with out breaking the bank is not easy. He just doesn't have that much in the budget right now for new ones! I'll find a set this year at one of the swap meets!! I hope hehe! Heres a little before and after on the wheels. The one thats done was the worst one and I'd say it turned out Ok!!
- cdnwillyg
I think okay is a little of an understatement, they look great!
:drive:Willy
:drive:Willy
That looks great! I have 2 friends with diesel pusher motorhomes that had severely oxidized aluminum wheels when they got them and I polished them out to an almost mirror shine so I can appreciate the work that goes into that - great job........
1997 Honda CBR 900RR
Update. They have been working hard on the truck. They have the cab pretty much done. The cab corners have been replaced and all body work done! They have the bed cleaned up and ready for a little TLC to the seam! I know there are posts about the seam sealer but can anyone tell me what is the best option for it! I need to get it ordered! Had a little miss hap with the seal for the back window when they removed the window, any suggestions for the best place for a seal? Thanks in advance for any help. Here's a couple pictures of the progress!
- Bullitt74
Regarding the body seam, I guess it depends on the duty and look you want it to have. Some guys weld it shut and grind it smooth. Some sandblast it clean and fill with lead. Others might want a factory look.
Dennis Carpenter has the best window gaskets, hands down. If you’re not installing the stainless, it should be relatively straightforward.
Looking good!
Looking good!
Steve F.
- flyboy2610
If you ARE installing the stainless trim, it has to go in before the gasket is installed on the truck.
Red Green
you'd better be right.
Red Green
Getting some color!! Someone cut the doors before he got it and they didn't have time to fix them before the end of the school year! So we're gonna mount some speakers in the holes!
- Bullitt74
That’s a really nice red!
Steve F.
Thats the same color red on my 2011 F250. He wanted it the same color as my truck. Their hard at it today. He wanted to keep the truck looking a little like a Coca Cola truck so he chose to do the bump and roof white!
