Pretty sure this isn't right.
Once had a truck with a 390. Engine self destructed. Went and got it up to the house to pull the 4x4 oil pan off of it. Found this:
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
1962 Fairlane 500 Sports Coupe
VW Sandrails
Honda ATC's
36' Diesel Pusher for roughing it.
1976 Highboy
VW Sandrails
Honda ATC's
Re: Pretty sure this isn't right.
Twizzler edition? Licorice special?
Dang.. that looks rough. She got bound up pretty tight
Pretty common when the valve seals clog up the oil pump
Take the screen off your oil pump pickup
it has a crossbar on it
under the crossbar is a gaping 5/8 hole
when the screen gets clogged
it sucks the screen up and bits and pieces
of the valve seal get sucked up into the pump and lock it up
- Ranchero50
Suction won't lock it up but a little piece of crap sucked through the screen will. Also negligent revving of the engine with really cold oil runs the risk of twisting the drive. Worth it to install a heavy duty oil pump drive next time. Also, high volume, not high pressure pump.
valve stem seals is exactly what i thought when i took apart the oil pump and found pieces of what looks like plastic. i cant see how it would get thru the screen, the pickup tube doesnt come apart. i will look harder to see if the screen is loose or something, since i want to reuse it.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
The screen is crimped into the bell
The cross bar is covering the hole
Do yourself a favor and buy a new pickup
Uncrimp the screen and you will see the hole in the screen
I have replaced the screen with one without the hole
I never said suction will clog the oil pump
what I said was the screen gets clogged
When that happens suction raises the screen off the cross bar and allows the pieces of valve seal to enter the oil pump
The pump locks up and twists the oil pump drive shaft
The plastic pieces you found were hardened valve seal material
- farmallmta
Best comment on the thread!
LOL. Good one!Twisted_Steel wrote:Twizzler edition? Licorice special?
Here's mine: He's halfway to a drillbit: just needs a little sharpening on the end.
I don't see any cross bar or hole, and can't seem to find a replacement. Please advise.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
I see how it works now. Screen gets clogged, screen gets sucked up, uncovers hole, craps get in.
Can't seem to find a new one, but screen is clean. Reuse?
This is a highboy oil pan/pickup tube.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
back in the day,we use to just clean then up and reuse,good old stp use to clog them up,
- Manny
undo the crimp around the edge and clean the screen out. Get yourself a arp oil pump driveshaft.
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
